/DT1/SHELL
Engine Keyword Alternative time step calculation method for shell elements which results in a lower more accurate time step than the default calculation method.
/DT1/SHELL/Keyword3
| Data | Description | SI Unit Example |
| Keyword3 | Time step control type:
| Scale factor on time
step. Default = 0.9 |
| Minimum time step. |
- This option activates a lower and thus more conservative time step calculation method for shell elements; otherwise, this option is identical to /DT/SHELL.
