/DT/AIRBAG/Keyword3
Engine Keyword Time step with airbag and time step control.
/DT/AIRBAG/Keyword3
| Data | Description | SI Unit Example |
| Keyword3 | Time step control type:
If Keyword3 is not specified, i.e. /DT/AIRBAG, then the entered is not used. |
| Scale factor on critical
time step for airbag. Default = 0.9 |
| Minimum time step. |
- /DT/AIRBAG/Keyword3 can be combined with /DT/NODA or /DT/NODA/CST.
