/H3D/SPRING
Engine Keyword Generate H3D contour output results for /SPRING spring elements.
/H3D/SPRING/Keyword3
#optional next line(s) that lists the parts to save results for
part_ID1... part_IDN
/H3D/SPRING/DT/H3D/SPRING/FORC
356 293Definitions
| Data | Description | SI Unit Example |
| Keyword3 | Output types. 3 | |
| part_IDN | Optional list of part IDs for which results will be output. |
- The syntax /H3D/ELEM/Keyword3 is also valid.
- When PART IDs are listed after the /H3D/SPRING line the specified results will only be output for those parts.
- The scalar output is defined in the
following tables.
Table 1. Scalar Output Keyword3 Description AMS Elements using AMS timestep due to /DT/CST_AMS. DAM1, DAM2, DAM3 Damage in direction 1, 2 or 3. 4 DT Element timestep. ENER Specific energy density (internal energy divided by the element mass). EPSP Plastic strain. F1, F2, F3 Force in local coordinate system. - F1
- Force in X direction
- F2
- Force in Y direction
- F3
- Force in Z direction
FORC All forces and moments in local coordinate system. F1, F2, F3, M11, M21, M31, M12, M22, M32.
M11, M21, M31, M12, M22, M32 Moment in local coordinate system. - M11
- Moment in X at node 1
- M21
- Moment in Y at node 1
- M31
- Moment in Z at node 1
- M12
- Moment in X at node 2
- M22
- Moment in Y at node 2
- M32
- Moment in Z at node 2
MASS Element mass OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- Between 0 and 1
- Under failure process.
- = 1
- Active element.
- Damage in springs is
defined as the maximum value between time 0 and the current time of the displacement
versus failure displacement ratio:
(1) For TYPE13 (/PROP/SPR_BEAM) springs, damage direction 1 is traction/compression, 2 and 3 are shear y and z.
For TYPE8 (/PROP/SPR_GENE) springs, damage directions 1, 2 and 3 are, respectively x, y and z.
