/H3D/PART
Engine Keyword Define which parts will be saved in the H3D file. The H3D file will only contain the model and result data for the listed part_IDs.
/H3D/PART
part_ID1... part_IDN
/H3D/PART
356 293 476 489 256Definitions
| Data | Description | SI Unit Example |
| part_ID1...part_IDN | The H3D file will only contain the model and result data for the listed part_IDs. |
