/H3D/BEAM
Engine Keyword Generate H3D contour output results for /BEAM beam elements.
/H3D/BEAM/Keyword3/Keyword4
/H3D/BEAM/VONM/H3D/BEAM/ENER
356 293Definitions
- The syntax /H3D/ELEM/Keyword3/Keyword4 is also valid.
- When PART IDs are listed after the /H3D/BEAM line, the specified results will only be output for those parts.
- The scalar output is:
Table 1. Scalar Output Keyword3 Keyword4 Description AMS Elements using AMS timestep due to /DT/CSdT_AMS. DT Element timestep. ENER Specific energy density (internal energy divided by the element mass). EPSP NPT=I or ALL Plastic strain. The integration point output NPT is only available for /PROP/TYPE18 (INT_BEAM). F1, F2, F3 Force in local coordinate system. - F1
- Force in X direction
- F2
- Force in Y direction
- F3
- Force in Z direction
FORC All forces and moments in local coordinate system. F1, F2, F3, M11, M21, M31, M12, M22, M32
M11, M21, M31, M12, M22, M32 Moment in local coordinate system. - M11
- Moment in X at node 1
- M21
- Moment in Y at node 1
- M31
- Moment in Z at node 1
- M12
- Moment in X at node 2
- M22
- Moment in Y at node 2
- M32
- Moment in Z at node 2
MASS Element mass. OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- = 1
- Active element.
SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX Stress in specified direction. VONM von Mises stress. - The output location in
Keyword4 can be defined via:
NPT = integration points
- Output can be requested for a specific location number (I), ALL. The output locations are separated by a forward slash (/) and can be in any order.
