/GRSPRI/GRSPRI
Block Format Keyword Describes the spring groups which are selected from other spring groups.
Enter selected items numbers (any number may be input, 10 per Line)
/GRSPRI/GRSPRI/grspring_ID/unit_ID
grspring_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
grspring_ID Spring group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grspring_title Spring group title
item_ID1, item_ID2,... item_IDn List of spring group identifiers
(Integer)
  1. If item_ID is a negative number, the item number is deleted from the group.
