/GRSHEL/PART
Block Format Keyword Describes the shell part groups which belong to given parts.
/GRSHEL/PART/grshell_ID/unit_ID | |||||||||
grshell_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
grshell_ID | Shell group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grshell_title | Shell group
item_ID1, item_ID2,..., item_IDn | List of part
identifiers (Integer) |
- Shell groups cannot contain 3 node shell elements (use /GRSH3N instead).
- If item_ID is a negative number, the item number is deleted from the group.
