/GRBEAM/GEN_INCR
Block Format Keyword Generates a group of beams by listing the first and last beam IDs in the range with a user-defined increment value.
/GRBEAM/GEN_INCR/grbeam_ID/unit_ID | |||||||||
grbeam_title | |||||||||
first_ID | last_ID | Incr |
grbeam_ID | Beam group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grbeam_title | Beam group
first_ID | First beam element
identifier in the list. (Integer) |
last_ID | Last beam element
Incr | Increment value of the
list generation from first_ID to
last_ID. Default = 1 (Integer) |
- The group includes first_ID, first_ID+Incr, first_ID+2*Incr, first_ID+3*Incr, … continuing through last_ID.
- Multiple first_ID, last_ID, and Incr lines can be defined in one block.
