/BOX/SPHER
Block Format Keyword Describes a spherical box for entities selection.
/BOX/SPHER/box_ID/unit_ID
box_title
N1     Diameter
Xp1 Yp1 Zp1
box_ID Box identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
box_title Box title.
N1 Node identifier.
Diameter Diameter of sphere.
(Real)
Xp1 X coordinate of point P1.
(Real)
Yp1 Y coordinate of point P1.
(Real)
Zp1 Z coordinate of point P1.
(Real)
The node N1, or the point P1, is used to define the center of the sphere.
box_spher
  1. A box (SPHER) defined above is used for:
