/ADMESH/SET
Block Format Keyword Defines the criteria for adaptive meshing in parts. This keyword is not available for SPMD computation.
/ADMESH/SET/adset_ID | |||||||||
adset_title | |||||||||
Angle Criterion | Inilev | Thkerr | |||||||
ID1 | ID2 |
adset_ID | Set for adaptive
meshing block identifier (Integer, maximum 10 digits) |
adset_title | Set for adaptive
meshing block name (Character, maximum 100 characters) |
Angle Criterion | Angle criterion for
mesh refinement. 3 (Real) |
Inilev | Initial level of
refinement.
(Integer) |
Thkerr | Criterion based upon
estimated thickness error. 4 (Real) |
ID1, ID2 | IDs of parts declared
for adaptive meshing within this set. (Integer, maximum 10 per format) |
- Several sets of parts may be declared for adaptivity, each using for instance, different angle criteria.
- A part declared for adaptivity can include 4-node shell elements or 3-node shell elements and use any shell element formulation; except DKT18 and DKT_S3 formulations for triangles.
- The Angle
Criterion (degrees) defines the maximum angle between two neighboring
elements; if this angle is reached, elements will be subdivided.The element normal is checked versus the averaged normal at nodes as:
- Element Normal is computed at the maximum level and normalized.
- Averaged normal at nodes are computed:
(1) - Normal at nodes is normalized.
- For each active element that is not at maximum level, the angle between
its normal and the normal at its nodes is computed; and if this angle is
greater than the defined criterion, the element is divided.
- If
Thkerr > 0, a thickness error estimation is computed as
follows:Nodal thickness is computed as:
(2) Where, and are the area and thickness of element containing node .
Then the thickness error is evaluated for each element, using the formula:(3) If the thickness error is greater than the criterion Thkerr, the element is divided.
- The Angle and thickness error criteria are only checked at frequency defined through "Time delay" format provided in /ADMESH/GLOBAL.
- Criteria Angle criterion and Thkerr can be used separately or combined.
- In Adaptive Meshing, Node ID and shell ID are limited to < 900000000.
