UNITS
I/O Options and Subcase Information Entry The UNITS command can be used in the I/O Options section to define a system of units for the model.
UNITS = system
| Argument | Options | Description |
| system | <SI,
CGS, MPA,
BG> No default |
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- This UNITS Data Entry is the same as the DTI,UNITS entry.
