RESTARTW
I/O Options and Subcase Information Entry The RESTARTW entry can be used in the I/O Options section to define the control parameters for nonlinear restart.
RESTARTW = n, option, path
RESTARTW = 1
RESTARTW = 5, NOCOV
RESTARTW = 5, NOCOV, D:\tmp
| Argument | Options | Description |
| n | Integer > 0 No default |
Identifies the frequency
of writing nonlinear restart analysis information files. Restart analysis information files (*.rnl) are written after every n increment(s) and after the last increment for a nonlinear subcase. 1 |
| option | COVER, COVE2, NOCOV |
| path | <directory
path> Default = Scratch file directory |
Path to the directory
where restart files are to be written. 2
Note: This argument is only supported if RESTARTW
is specified above and outside the subcase.
- If RESTARTW entry is specified in the model, OptiStruct writes one restart model information file (*.rmd) and one or more restart analysis information files (*.rnl) to be used in a subsequent restart run. The .rnl and .rmd files are named in format <filename>_sub<i>_inc<j>.rnl and <filename>.rmd respectively, where <filename> is the filename of the input deck (prior to .fem), <i> (0<i<100000000) is the corresponding subcase ID and <j> (0<j<10000) is the corresponding increment number in the subcase.
- RESTARTW entry can be specified on top of subcases and/or inside subcases. If prescribed both ways, the in-subcase RESTARTW arguments overrides the out-of-subcase RESTARTW arguments except for the path option.
- For information on restart of Nonlinear Analysis, refer to Requirements for Restarting in the User Guide.
- RESTARTW and RESTARTR entries can be specified together, except for the very first run (that is, the original job that is subsequently restarted), where only RESTARTW is allowed.
