PFPANEL
I/O Options and Subcase Information Entry The PFPANEL command can be used in the I/O Options section to request output of acoustic panel participation factors for all Modal Frequency Response subcases.
PFPANEL (PANEL=setp, FREQUENCY=setf, outfile,peakout,form) = setdof/PEAKOUT
Examples
PFPANEL(PANEL=ALL,FREQUENCY=45)=12
PFPANEL(H3D, PEAKOUT)=56
PFPANEL(H3D, PEAKOUT)=PEAKOUT
PFPANEL(PUNCH, PHASE)=32
| Argument | Options | Description |
| setp | <ALL,
NONE> Default = NONE |
| setf | <ALL, SID> Default = SID |
| outfile | <PUNCH, H3D> Default = H3D |
Panel participation can be exported either into a H3D file or a PUNCH file. Because of the large volume of data, it is recommended to export the panel participation data into a H3D file. |
| form | <REAL, IMAG, PHASE> |
| peakout | If peakout is present as an option inside the parentheses of the PFPANEL data, the filtered frequencies from the peakout data will be considered for output of panel participation. | |
| setdof/PEAKOUT | <SID/PEAKOUT> | Degrees-of-freedom for which the panel participation factors are to be processed. SID refers to the ID of a SET of type GRID. If peakout is specified instead of SID, the output will be considered at the filtered frequencies corresponding to the degree-of-freedom in the peakout card in the bulk section. |
- Output is to the H3D or PUNCH files only. The output of both PFMODE and PFPANEL must be either to an H3D file or to a PUNCH file. Both PFPANEL and PFMODE must have the same output option.
- Acoustic panel participation factors are available in a coupled Frequency Response Analysis (Modal Frequency Response only).
- The FREQUENCY keyword can be used to select a subset of excitation frequencies available. The closest loading frequency will be chosen in this case.
- Legacy format for the export of acoustic panel participation to H3D or PUNCH files: PFPANEL (OUTPUT=outfile)=setdof/PEAKOUT is also supported.
