SPOWER
I/O Options and Subcase Information Entry The SPOWER command can be used in the I/O Options or Subcase Information sections to request Sound Power output for all subcases or individual subcases, respectively. SPOWER can only be requested for frequency response subcases.
SPOWER(type) = option
| Argument | Options | Description |
| type | <PANEL, NOPANEL> Default = PANEL |
| option | <ALL> Default = ALL |
- When the SPOWER command is present, Sound Power is output for all RADSND panel grids and all microphone grids for all frequency response subcases.
- Sound power is always output for microphone locations regardless of the specified type (PANEL/NOPANEL).
- Sound Power results (via SPOWER) are output to the .h3d file.
