MDSDIR
I/O Options EntryUsed to choose the location of the Altair Multiscale Designer™ installation.
MDSDIR=path
MDSDIR = “C:\Program Files\Altair\2021\hwsolvers\MultiscaleDesigner"
| Argument | Options | Description |
| path | <directory
path> Default: See Comment 1 |
Path to the location of the Multiscale Designer installation. |
- OptiStruct will automatically use the Multiscale Designer installation within the same HyperWorks Solvers installation from which OptiStruct is being run. If you want to use a different Multiscale Designer installation, then the MDSDIR entry can be used.
- The MATMDS Bulk Data Entry references the ASSIGN entries, which point to the corresponding material model data files from Multiscale Designer.
- MDSDIR can also be defined in the OptiStruct Configuration File.
