MONITOR
I/O Options and Subcase Information Entry Controls the printing of monitor point data to the .monpnt file, whenever monitor points (MONPT1/MONPNT2/MONPNT3) are defined in the model.
MONITOR (nopnt1, nopnt2, nopnt3) = option
MONITOR (NOPNT1) = ALL
MONITOR (NOPNT1, NOPNT2) = NONEDefinitions
| Argument | Options | Description |
| nopnt1 2 | <NOPNT1, blank> |
| nopnt2 2 | <NOPNT2, blank> |
| nopnt3 2 | <NOPNT3, blank> |
| option | <YES, ALL, NO,
NONE, blank> Default = ALL |
- This entry is supported only for linear static and static aeroelastic analysis.
- NOPNT1, NOPNT2 and NOPNT3 options are available only for linear static analysis and will be ignored in static aeroelastic analysis.
- If a model has at least one load
monitor point
(MONPNT1/MONPNT2/MONPNT3)
defined:
- For linear static analysis, the .monpnt file will be generated only in the presence of the MONITOR I/O Option.
- For static aeroelastic analysis, the .monpnt file will be generated automatically.
- The output is printed to the .monpnt ASCII file.
