FLUX
I/O Options and Subcase Information Entry Used to request temperature gradient and flux output for all steady-state heat transfer analysis subcases, transient heat transfer analysis subcases or individual heat transfer analysis subcases, respectively.
FLUX (format_list) = option
| Argument | Options | Description |
| option | <PUNCH, OP2, H3D, PLOT, blank> |
| option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- When the FLUX command is not present, flux results are not output.
- Flux output is only available for Steady-State Heat Transfer Analysis and Transient Heat Transfer Analysis solution sequences.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
