Volume Mesh Optimization Flag
Volume mesh optimization flag turns on/off volume optimization. By default it is set to On.
View new features for AcuSolve 2021.
AcuSolve is a leading general purpose CFD solver that is capable of solving the most demanding industrial and scientific applications.
Discover AcuSolve functionality with interactive tutorials.
Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy of AcuSolve results.
AcuSolve command descriptions and corresponding examples.
AcuSolve utility programs covering preparatory and post-processing as well as user-defined functions and utility scripts.
Customization of AcuSolve allowing you to customize certain capabilities of the solver.
Instruction of the mesh generation capability in AcuConsole, a GUI based pre-processor for AcuSolve.
Mesh attributes control various aspects of the mesh generation process, including mesh size. Mesh attributes can be set on a global (whole model) and/or local (model entity) basis.
AcuMeshSim is a standalone C++ program. It can be run from the command line, but is more often run directly from AcuConsole.
Mesh controls are used to control the size and characteristics of the mesh in different areas of the model.
Mesh size can be roughly equated to the edge length of the elements generated by the mesh generator.
Curvature meshing attributes are extremely useful for capturing the curvature in the model during mesh generation.
Periodic boundary conditions are used in AcuSolve when only a subset of the full flow domain is simulated.
In certain simulations the flow domain may have a very high aspect ratio.
Mesh size can also be specified as a function of location. Geometric shapes such as spheres, boxes and cylinders can be drawn and mesh sizes are specified for the volume enclosing these Zone Mesh Attributes.
The Global Mesh Attributes represent mesh settings that are applied to the entire model. Additionally, the size specified in this panel is used as the global mesh length scale that is used in the octree method when evaluating all subsequent mesh sizes.
All of the mesh features in this section are advanced, and in most cases you do not need to change any of them.
Ensure elements have interior vertices modifies the mesh to ensure that it has at least one vertex in the interior.
Shrink mixed flag sets the method that the boundary layer uses to resolve overlapping mixed volumetric elements.
Surface mesh snap on match flag turns on/off the "snapping" of destination vertices during the mesh matching. By default it is set to On.
Surface mesh smoothing flag is set to On by default.
Surface mesh proximity size level performs isotropic refinement of the surface mesh in areas determined to be thin through the volume.
Surface mesh face rotation angle limit sets the face rotation limit angle for meshing discrete models.
Surface mesh fix intersections flag is set to On by default. This sets how the surface mesher checks for and fixes self intersections.
Volume mesh smoothing flag by default is set to On. This provides an option (Volume mesh smooth level) for setting the level of volume mesh smoothing.
Volume mesh enforce size flag controls interior mesh size enforcement.
Surface mesh improver flag is set to Off by default. Turning it On provides additional options for surface mesh improvement.
Volume mesh improver flag is set to Off by default. Turning it to On provides additional features for volume mesh improvement.
Boundary layer minimum aspect ratio flag sets the length-to-height aspect ratio target value for boundary layer elements.
2D Boundary layer minimum aspect ratio flag sets the length-to-height target aspect ratio value.
Boundary layer exposed ratio flag sets the height-to-length exposed aspect ratio for boundary layer elements.
Edge blends smoothing flag sets additional behavior to grade heights of edge blend boundary layers.
By enabling the Small feature meshing flag, you can set the type and tolerance for meshing of small features in the model.
Every geometric model in AcuConsole contains one or more volume groups. The pipe example model has one volume group called fluid with one geometric region.
Once the geometry is imported into AcuConsole, it will have one or more surface groups. Each of the surface groups could have one or more geometric faces associated with it.
To properly set periodic boundary conditions in AcuSolve, the mesh nodes on periodic faces must match after applying the periodic transformation.
Extrusion meshing is a technique in which structured mesh is created in volume and on surface entities.
The Zone Mesh Attributes panel provides a method for you to set mesh sizes in regions that are independent of the CAD model.
An edge mesh specifies mesh attributes along a selected edge of a model.
Generating a mesh using AcuConsole requires you to set up the mesh attributes and open the Launch AcuMeshSim dialog by clicking Tools > Generate Mesh.
Customization of AcuConsole allowing you to improve your particular workflow.
Commands of AcuTrace, a particle tracer that runs as a post-processor to or a co-processor with AcuSolve.
Instructions to define additional solution quantities of AcuTrace called user equations.
Usage of AcuFieldView, an OEM version of Intelligent Light’s FieldView post-processing software.
Instruction of the AcuReport tool, a standalone post-processor batch tool used to generate a report from an AcuSolve solution database.
