Mesh Generation Process
Generating a mesh using AcuConsole requires you to set up the mesh attributes and open the Launch AcuMeshSim dialog by clicking .
- An input file with mesh attributes. This file has an .ams extension.
- A file with the geometry data.
The .ams file is an .xml file that is read by the AcuMeshSim executable. Providing this file as input to AcuMeshSim allows you to launch the mesh generator from the command line.
The following sections discuss the settings that are available in the Launch AcuMeshSim dialog.
