Periodic Mesh Attributes
To properly set periodic boundary conditions in AcuSolve, the mesh nodes on periodic faces must match after applying the periodic transformation.
The mesh generation process must ensure that the periodic node matching is created properly within the resulting mesh. It should be noted that periodic meshing is not supported when using discrete CAD formats ( Nastran and STL).
