Separated Laminar Flow Over a Blunt Plate
In this application, AcuSolve is used to simulate the separation of laminar flow over a blunt plate. AcuSolve results are compared with experimental results as described in J.C. Lane and R.I. Loehrke (1980). The close agreement of AcuSolve results with the experimental results validates the ability of AcuSolve to model cases with external laminar flow including separation.
Problem Description
![](../../images/acusolve/separated_laminar_flow_over_a_blunt_platef1.png)
![](../../images/acusolve/separated_laminar_flow_over_a_blunt_platef2.png)
Figure 2. Mesh used for Simulating Separated Laminar Flow over a Blunt Plate
![](../../images/acusolve/separated_laminar_flow_over_a_blunt_platef3.png)
Figure 3. Mesh Detail Showing Refinement Zones at the Leading Edge of the Blunt Plate
![](../../images/acusolve/separated_laminar_flow_over_a_blunt_platef4.png)
Figure 4. Mesh Detail Showing Mesh Elements Near the Leading Edge of the Blunt Plate
AcuSolve Results
![](../../images/acusolve/separated_laminar_flow_over_a_blunt_platef5.png)
Figure 5. X-Velocity Contours Near the Leading Edge of the Blunt Plate
![](../../images/acusolve/separated_laminar_flow_over_a_blunt_platef6.png)
Figure 6. X-Velocity Contours Showing the Recirculation Zone Near the Plate Edge (only Nodes with an X-Velocity ≤ 0 are Displayed)
AcuSolve xreattach | AcuSolve xreattach/T | Experimental xreattach/T | Percent error (%) |
0.3775 | 4.194 | 4.00 | 4.86 |
Summary
In this application, a constant flow inlet velocity and symmetric boundary conditions were used to model 2D flow over a blunt plate. The AcuSolve solution compares well with experimental results for the separation of laminar flow over a blunt plate. The non-dimensional reattachment length obtained from the AcuSolve steady state solution compares well with the experimental solution, with an error of less than 5.0 percent. The results of this simulation validate the ability of AcuSolve to accurately predict the reattachment point in cases with external, laminar flow with separation.
Simulation Settings for Separated Laminar Flow over a Blunt Plate
AcuConsole database file: <your working directory>\blunt_plate_laminar\blunt_plate_laminar.acs
Global
- Problem Description
- Analysis type - Steady State
- Turbulence equation - Laminar
- Auto Solution Strategy
- Relaxation Factor - 0.2
- Material Model
- Fluid
- Density - 1.0 kg/m3
- Viscosity - 1.7894e-005 kg/m-sec
Model
- Fluid
- Volumes
- Fluid
- Element Set
- Material model - Fluid
- Element Set
- Fluid
- Surfaces
- Back
- Simple Boundary Condition
- Type - Symmetry
- Freestream
- Type - Slip
- Front
- Type - Symmetry
- Inlet
- Type - Inflow
- Inflow type - Velocity
- Inflow velocity type - Cartesian
- X Velocity - 0.045133 m/s
- Outflow
- Type - Outflow
- Plate
- Type - Wall
- Symmetry
- Type - Symmetry
- Back
References
J.C. Lane and R.I. Loehrke. "Leading Edge Separation from a Blunt Plate at Low Reynolds Number". Journal of Fluids Engineering. 102(4):494-496. 1980.
