Laminar Poiseuille Flow Through a Pipe
In this application, AcuSolve is used to simulate the flow of carbon dioxide (CO2) entering a pipe with a fixed velocity. AcuSolve results are compared with analytical results using the Hagen-Poiseuille approach as described in White (1991). The close agreement of AcuSolve results with analytical results validates the ability of AcuSolve to model cases with constant flow velocity.
Problem Description
![](../../images/acusolve/laminar_poiseuille_flow_of_carf1.png)
Figure 1. Critical Dimensions and Parameters for Simulating Laminar Poiseuille Flow Through a Pipe
![](../../images/acusolve/laminar_poiseuille_flow_of_carf2.png)
Figure 2. Mesh Used for Simulating Laminar Poiseuille Flow Through a Pipe
AcuSolve Results
![](../../images/acusolve/laminar_poiseuille_flow_of_carf3.png)
Figure 3. Pressure Contours and Velocity Vectors
Analytical pressure drop (Pa) | AcuSolve pressure drop (Pa) | Percent deviation from analytical | |
Inlet to outlet pressure drop | 2.242 | 2.245 | 0.099 |
Summary
The AcuSolve solution compares well with analytical results for laminar flow through a pipe. In this application, the pressure drop along the length of the pipe is caused by the viscous shearing near the pipe wall. The AcuSolve steady state solution compares well with the analytical solution, with less than 0.1 percent error.
Simulation Settings for Laminar Poiseuille Flow Through a Pipe
AcuConsole database file: <your working directory>\pipe_laminar\pipe_laminar.acs
Global
- Problem Description
- Analysis type - Steady State
- Turbulence equation - Laminar
- Auto Solution Strategy
- Relaxation factor - 0.2
- Material Model
- CO2
- Density 1.808 kg/m3
- Viscosity 1.46e-5 kg/m-sec
Model
- CO2
- Volumes
- Fluid
- Element Set
- Material Model - CO2
- Element Set
- Fluid
- Surfaces
- Inflow
- Simple Boundary Condition - (disabled to allow for periodic conditions to be set)
- Advanced Options
- Integrated Boundary Conditions
- Mass Flux
- Type - Constant
- Constant value - -2.6625e-05 kg/sec
- Mass Flux
- Outflow
- Wall
- Type - Wall
- Inflow
- Periodics
- Periodic 1
- Individual Periodic BCs
- Velocity
- Type - Periodic
- Pressure
- Type - Single Unknown Offset
- Velocity
- Periodic 1
References
F. M. White. "Viscous Fluid Flow". Section 3-2.1. McGraw-Hill Book Co., Inc.. New York. 1991.
