Oscillating Laminar Flow Around a Circular Cylinder
In this application, AcuSolve is used to simulate two dimensional, laminar flow over a cylinder to predict separation of flow from the cylinder surface and the flow in the wake area. AcuSolve results are compared with experimental results as described in Tritton (1959). The close agreement of AcuSolve results with experimental results validates the ability of AcuSolve to model cases with unsteady oscillating vortex streets.
Problem Description
Figure 1. Critical Dimensions and Parameters for Simulating Oscillating Laminar Flow Around a Circular Cylinder
Figure 2. Mesh used for Simulating Oscillating Laminar Flow Around a Circular Cylinder
Figure 3. Details of the Mesh Showing Refinement Zone Around the Cylinder
AcuSolve Results
Figure 4. Contours of Velocity Magnitude
Figure 5. Lift Coefficient (lift force perpendicular to flow) plotted against time. Simulation was run for 600 time steps for a duration of 60 s
where ω is the dominant frequency of oscillations, L is the diameter of the cylinder, and v is the flow velocity.
| Experimental | AcuSolve | |
| Strouhal number | 0.165 | 0.167 |
Summary
In this application, two dimensional flow over a cylinder is achieved by enforcing symmetry conditions on the front and back surfaces of the flow domain. The laminar, unsteady simulation shows the flow separation that leads to alternating vortex shedding. Frequency of the lift force acting on the cylinder is calculated to evaluate the Strouhal number. The AcuSolve solution compares well with results reported by Tritton (1959), differing from the experimental results by less than 1.5 percent. In this application, AcuSolve demonstrates the ability to accurately predict oscillating laminar flow around a circular cylinder.
Simulation Settings for Oscillating Laminar Flow Around a Circular Cylinder
AcuConsole database file: <your working directory>\cylinder_laminar\cylinder_laminar.acs
Global
- Problem Description
- Analysis type - Transient
- Turbulence equation - Laminar
- Auto Solution Strategy
- Max time - 600 sec
- Initial time increment - 0.1 sec
- Material Model
- Fluid
- Density - 1.0 kg/m3
- Viscosity - 1.0e-3 kg/m-sec
- Fluid
- Output
- Nodal Initial Condition
- Pressure initial condition - Nodal Values
- Nodal Values - (provided in .acs)
- Velocity initial condition - Nodal Values
Model
- Volumes
- Volume
- Element Set
- Material model - Fluid
- Element Set
- Volume
- Surfaces
- Back
- Simple Boundary Condition
- Type - Symmetry
- Base
- Type - Slip
- Front
- Type - Symmetry
- Inflow
- Type - Inflow
- Inflow Type - Average velocity
- Average Velocity - 0.5 m/sec
- Outflow
- Type - Outflow
- Top
- Type - Slip
- Back
References
D.J. Tritton. "Experiments on the Flow around a Circular Cylinder at Low Reynolds Number". Journal of Fluid Mech. 6(04):547-567. 1959
