Relative Anisotropic Mesh Size
To specify a Relative anisotropic mesh type, set the Mesh size type to Relative Anisotropic. This option allows you to enter a relative size and a tensor that defines the orientation of the anisotropy.
Note that the tensor must define 3 orthogonal vectors. The size is evaluated by multiplying the relative size by the orientation tensor, then multiplying the length of the longest edge of the bounding box that completely encloses the entire model to determine the final size used by the mesher. The mesher has a practical limit onanisotropy of approximately 5:1. Requests for higher levels of anisotropy in unstructured mesh regions will most likely not be satisfied.
