Curvature Mesh Size Factor
Curvature mesh size factor is used to determine the minimum value of the mesh edge length used to resolve curved features.
This minimum value is computed by multiplying the Absolute or Relative mesh size with the Curvature mesh size factor.
Note: If you use curvature-based refinement on surfaces that have curvature singularities (for example the tip of a cone), you must specify a reasonable minimum curvature size either globally or for that surface. Otherwise, extensive amounts of mesh refinement will take place.
