Relative Mesh Size
If the Mesh size type is set to Relative, the Relative mesh size has to be specified.
The actual mesh size will be computed by multiplying the Relative mesh size with the largest edge length of the bounding box for each geometric face in the surface group. Note that this means a different mesh size may be used for each face in the surface group.
