Curvature Refinement Parameters
The Curvature refinement parameters for a surface work in the same way as the ones used in Volume Mesh Attributes. The only difference is that they are applied on each of the geometric faces in the surface group.
![](../../images/acusolve/curvature_refinement_parameters_surface_meshf2.png)
