Manufacturing Solutions
Moldex3D Solid Utility Menu
The Moldex3D Solid Utility menu consists of buttons that provide shortcuts to different functions. The layout of the buttons mimic the process flow required to set up a model for Moldex3D Solid.
The main Utility menu is shown below, along with descriptions of function.
moldex3D_solid_utility_menu
Surfaces
Cleanup
Shortcut to the Edge Edit panel. This shortcut provides quick access to the Edge Edit, Defeature, and Point Edit panels for geometry cleanup operations.
Midsurface
Shortcut to the Midsurface panel, which provides tools to extract a midsurface from selected surfaces.
Lines
Create
Shortcut to the Lines panel, which is used to create lines.
Edit
Shortcut to the Line Edit panel, which is used to edit lines.
Extract Axis
Opens the Extract Axis dialog, which extracts the axis of the given solid. See Extract Axis for more details.
Generate Mesh
Coolant Channel Line
Opens the panel to generate 1D beam mesh for the coolant channel.
Surface Mesh
Opens the size and bias subpanel of the Automesh panel, which is used to create tria3 elements on surfaces.
Layered Tet Mesh
Opens a submenu of macros for generating a layered CFD solid mesh. See Layered Tet Mesh Submenu.
Solid Meshing Wizard
Opens the Solid Meshing Wizard, which facilitates meshing the solids either with solidmap, tetmesh or CFD mesh.
Runner Meshing Wizard
Opens the Runner Meshing Wizard, which contains a dialogs that help create a high quality solid mesh for the runner system consisting of prism and tetrahedral elements. See Runner Meshing Wizard.
Moldex3D Wizard
Opens the Moldex3D Wizard tab, which contains a step-by-step procedure to set up an Boundary Layer 3D Mesh See Moldex3D Wizard.
Model Setup
Create Property Cards
Opens a submenu for setting up the model. See Create Property Cards for details.
Diagnostics
Computes the element quality of the displayed solid elements.
Export
Opens the Moldex3D MFE Export dialog for exporting the model. See Export for details.
See Also:
Moldex3D Wizard
Create Property Cards Submenu
