Manufacturing Solutions
Create Property Cards Submenu
The following image displays the Create Property Cards submenu.
create_prop_cards_submenu
Solid Mesh
Opens a selector for elements so that you can assign/edit property cards pertaining to solid mesh such as Cavity (Part), Cold Runner and Hot Runner.
Fast Cool Analysis
Surface Mesh
Opens a selector for surface elements so that you can assign/edit property cards pertaining to surface meshes for moldbase and mold insert while doing fast cool analysis
Coolant Channel
Opens a selector for beam elements so that you can create coolant channel and heating rod while doing fast cool analysis.
BCs
Points
Opens a selector for nodes so that boundary conditions such as Melt Entrance, Coolant Entrance and Coolant Exit can be defined on the node.
Surface Element
Opens a selector for solid elements so that surface element boundary condition can be defined on the surface element of that solid element.
<<<Back
Opens the main Moldex3D Solid Utility menu.
