Manufacturing Solutions
Points Property Cards
Three type of point properties are supported in this release. They are Fix Node, Measure Node and Sensor Node. When you click the Points button, a selector for a single node appears as shown below.
node_selector_panel
On picking the node from the model, the following dialog appears.
Point_properties_cards
The type of point can be chosen from the drop down list. For Sensor Node, the node ID to be displayed in the Moldex3D solver can be specified in the Node ID field as shown below.
sensor_node
See also
Solid Mesh Property Cards
Boundary Condition Cards
