Manufacturing Solutions
Creating Lines
Creating Lines
Creating Lines
Lines are used to create beam elements for modeling the feed system and cooling circuit. ROD (61) elements are used. The Moldflow template denotes "rod" as "beam" on the screen so as to use the same terminology as Moldflow.
In the Lines group of the Utility menu, the Create macro opens the Lines panel, which is used to create lines. The Edit macro opens the Line Edit panel, which is used to edit lines.
See Also:
Moldflow Utility Menu
