Manufacturing Solutions
Generating Mesh
Generating Mesh
Generating Mesh
After preparing the surfaces and creating lines for feed systems, you generate mesh on the surfaces. The Generate Mesh group includes buttons for various mesh-related actions.
generate_mesh_menu
The Moldflow data deck can be used for three different types of elements: linear triangular elements, linear tetrahedron elements, and linear beam elements (rod inside HyperMesh).
Element Type
Tria
Opens the size and bias subpanel of the Automesh panel, which is used to create tria3 elements on surfaces.  Note that Moldflow decks do not allow quad elements.
Beam
Opens the Line Mesh panel, which is used to create rod elements for the design of the feed system and cooling circuit.
Layered TetMesh
Opens a secondary Utility menu page with tools to create solid 3D models.
See Also:
Layered Tet Mesh Submenu
Flow 3D Wizard
