Manufacturing Solutions
Moldex3D Solid MFE Export
The  Moldex3D Solid interface is capable of exporting the models in the native MFE format. The export functionality is limited to only Windows platform. Click the Export button in the Utility Menu to open the Moldex3D MFE Export tab, as shown below.
moldex3d_mfe_export_tab
For Standard Cool model type, coolant channel, moldbase and mold insert meshes have to be solid meshes. For Fast Cool model type, coolant channel mesh has to be to a 1D mesh. Both moldbase and mold insert meshes have to be surface meshes. For export, only displayed elements are taken into consideration.
See also
Moldex3D Solid Utility Menu
