Manufacturing Solutions
Incremental_RADIOSS Macro Menu
The Incremental_RADIOSS macros are grouped based on the application, although several of them are common for different applications. The selected macro in the Application group determines which macros appear below.
inc_rad_application_menu
Form
Lets you set up a single-stage forming analysis.
Bend
Lets you set up a rotary draw tube bending and triggers the following buttons under the Setup grouping:
Bending Model Creator
Bending Setup
Defines the parameters for a tube bending analysis.
List
Displays a table summarizing the attributes for different components in the model. The component attributes can be easily modified by editing this table.
Spherical joint
Creates a spherical joint.
Hydro
Lets you set up a hydroforming analysis.  Triggers the following buttons under the Setup grouping:
Import STA
Rename
Import Tooling
Hydro Setup
Lets you define the parameters for a hydroforming analysis.
Blank Optimizer
Submenu of macros that help you optimize a mesh so that it follows the trim line as closely as possible.
TL Opti
Lets you trim by elements or components. The trimming by components option can trim only the elements inside the trim line.
Die Compensation
Compensates for die springback on the blank.
Model
HF
Imports a file saved in an earlier session.
CAD
Imports external CAD files.  Commonly used, supported file formats include: CATIA, IGES, STL, PDGS, VDAFS, UG18 and UG_NX.
FE
Imports input decks corresponding to different FE solvers.  Commonly used, supported solver formats include: OptiStruct, Nastran, ANSYS, Abaqus, LS-DYNA, RADIOSS, PAM-CRASH 2G, MoldFlow, etc.
Remove Holes
Identifies all pinholes < 100mm diameter on the displayed surfaces and allows you to delete them.
R-Mesh
Opens the R Mesh macro.
B-Mesh
Opens the Blank Surface Meshing dialog, on which you can specify an average edge length and mesh selected surfaces.
Check Elems
Lets you verify the basic quality of your elements and the geometric qualities of those elements.
Setup
Sections
Lets you define section properties, including thickness.
Materials
Lets you define material properties.
Database…
Lets you define materials and review the material’s properties.
Comps
Lets you create tool and blank components and assign their section and material properties.
List…
Displays a table summarizing the attributes for different components in the model.  The component attributes can be easily modified by editing the table.
Symmetry...
Lets you define the symmetry planes in a model.
Constraints
Lets you define boundary conditions.
Tool Setup
Automatically creates and positions the tools for stamping analysis.
Tool Motion
Lets you define the tool motion parameters, as well as the solution control and output history parameters.
Tool Load
Lets you define the force on a blankholder or pad, and activates a rigid body stopper.
Drawbeads
Lets you define the drawbeads and the corresponding restraining forces. Either a line or a set of nodes may be used to describe the drawbead location.
Editor...
Opens the Drawbeads Editor.
Contacts
Lets you set up either single or multiple contact definitions between the blank and tools.
Save
Saves your file.
Run
Launches a Dyna analysis and lets you select the component for which a Dyna ASCII output is required during subsequent analysis.  From here, you can also get a summary of your model and a preview of the tool motion before launching the analysis.
Auto Process
Provides an easy-to-use setup for various process types. The Auto Process macro prompts you for all necessary parameters for a given analysis type.
Multi-stage Manager
Provides a convenient graphical setup for process sequences that include multiple stages of processing. The Multi-stage Manager also enables you to define the parameters for each process stage.
Results
Load Results
Lets you directly launch the post processor (HyperView) with the results for the current model.
Report Generator
Creates an HTML-based or PowerPoint presentation containing results from the forming analysis. Choose from among five result types and export as H3D, JPEG, or AVI files.
Note: End users reviewing the resulting report must have HyperView Player (7.0 SP1,SA-042 and above) installed to take full advantage of the animation features in the report.
