Configure Model Verification Settings
Overview of various settings that can be configured for Model Verification.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Use the Verification Browser to inspect CAD data supplied from your design or CAD team.
Use the Comparison Browser to compare and identify the topology difference between two models/part assemblies/parts.
Import a model using Model Verification.
Perform various model checks in the Verification Browser.
Specify default values for Model Verification .log file settings.
Specify defaults for CAD model import file extensions.
Specify defaults for FE model solver types, version and file extensions.
General defaults for the Model Verification instance.
Defaults for the offset functionality of Model Verification.
Default values for the offset functionality of Model Verification.
Configurations for the intersection check functionality.
Specify defaults for the spotweld check functionality of Model Verification.
Connection check configurations.
Spot comparison check configurations.
Free part check configurations.
CSV comparison tool compares CAD/FE attributes against CSV file column.
Naming conventions used in various Model Verification Modules.
Report outputs and visualization configuration.
Save Representations in the input folder.
Configure any part.
Review the selected Part Assembly/Part in HyperView Player.
Review the selected Part Assembly/Part in HyperWorks graphics.
Export part representations.
Rename and set PIDs for all parts.
Renumber PIDs for all parts.
Get the count of the selected Part Representations.
Group parts based on size and shape.
Run Model Verification operations in batch mode.
Limitations of the Model Verification tool.
Use the curve editor to create and plot XY curves.
Define physical and mathematical characteristics of parts.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
