fe
Specify defaults for FE model solver types, version and file extensions.
Settings
type
Supported CAD file format.
Default/Allowed: dyna, nastran, pam, radioss, abaqus, optistruct, connector or hypermesh.
dyna
File extension of LS-DYNA input file. You can add many extensions for this type.
version
971
extension
.k, .key, .dat, .dyn*, or .dynain.
nastran
File extension of Nastran input file. You can add many extensions for this type.
extension
.bdf, .bulk, .blk, .dat, .nas or .nastran
pam
File extension of PAM-CRASH input file. You can add many extensions for this type.
version
2015
extension
.pc or .dat
radioss
File extension of Radioss input file. You can add many extensions for this type.
version
120
extension
.d00, .d01, .rad or ._000.d01
abaqus
File extension of Abaqus input file. You can add many extensions for this type.
version
Explicit, Standard.2d or Standard.3d
extension
.imp or .pes
optistruct
File extension of OptiStruct input file. You can add many extensions for this type.
extension
.fem
connector
File extension of Connector input file used for Spot weld check and Spot comparison function. If the type specified here and the actual file extension are not matching, the Check will not be executed.
version
971
extension
.vip, .mcf (HM format), .mwf, .xml (HM format)
hypermeshcad
The file extension of the HyperMesh file contains mesh only.
extension
.hm
Import Settings
fe-attached
Parts with node sharing are organized into one part if the thickness of these parts is not the same. The organization will not be executed if the thickness of these parts are the same.
Default/Allowed: ON or OFF
partName-string
Component name rule for fe-attach in addition to shared node rule. Input accepts first index through second index. The default, 0-0, or a blank value will ignore this rule and execute the share node based fe-attach function.
fe-detach
LH and RH parts will be separated. There will be two separated physical parts in case these two parts are organized into one part.
importby
While importing fe data into HyperMesh creating components by reading HyperMesh Comments or by reading HyperMesh information managed in the HyperMesh file.
Default/Allowed: hmcomments or property
Include-stamping
Reads stamping result information, such as element shell thickness, from the solver deck. This information will be used for mass calculation. Property thickness will be ignored if this option is ON.
dummy-thickness
Assigns a dummy thickness for the FE data. This dummy thickness is needed for CAD solid vs FE comparison in case no thickness exists from the original FE.
Default/Allowed: ON or OFF.
