csv-comparison
CSV comparison tool compares CAD/FE attributes against CSV file column.
Settings
mapattributes
displayname
Displays the Part Number.
PID
Displays the entity specific Property ID’s. At the Part level it displays IDs for referenced properties. At the Component level it shows the ID of the referenced property.
Part Name
Displays the Part entity name.
Material
Displays the material name of the Part.
Thickness
Displays the entity specific thickness. At the Part level it displays the thicknesses of the referenced properties. At the Component level it shows the thickness of the referenced property.
Function Name
Displays sub assembly name of the Part.
Assembly Name
Displays assembly name of the Part.
Weight
Displays weight of the Part.
Configuration Options
csvcomparison/compare
Compares only the attributes between CSV and MVD attributes and results will be displayed in Error column.
csvcomparison/compare-update
Compares and updates the attributes if mismatch exist in the attributes.
csvcomparison/NewXML
CSV file will be converted to BOM and added as Variant BOM for future topology comparison.
reference-item
It is Common attribute name between FE/CAD model and CSV file header.
string-match-format
Generic
Full string vs string will be compared.
Prefix
Pre-fix, base-name, post-fix will be compared in the CSV file part name.
report
Excel report will be generated with model image in JPEG/H3D.
report-dir
Output path for report.
