Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Review the selected Part Assembly/Part in HyperWorks
graphics.
This review function uses parallel processing and is used in case of huge number of
selected part and it takes time in normal import operation.
Once the model is displayed in the graphics, you can select unwanted parts in the
graphics and delete them; simultaneously, the Part Browser gets
updated.
Note: The number CPU set in the configuration general section is used
for parallel processing.
It is recommended to use this function before CAD Intersection or Comparison is
executed for full car model where it is not sure the parts are in right
position. Figure 1. Intersection Check on Each CPU
Right-click in the Verification/Comparison Browser and select Review
Results from the context menu.
