Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
After the check, groups are created under the Part Browser/Part
Set Browser. To execute the classification, parts are mandatory. Select the root
part from the Verification Browser or the Comparison Browser and run Classify.
From the Verification Browser/Comparison Browser, right-click and select Parts > Match from the context menu.
From the Method drop-down menu, select either AI or
Shape.
In the Similarity (%) field, type the desired same shape match%. The default is
50%.
In the Tolerance field, type the search tolerance to use to find matching
entities. The default is 0.1mm.
In the Max Area field, type the maximum area to search.
In the Min #Surface field, type the minimum number of surfaces to use.
