Edit Entities
Modify entity parameters.
  1. Do one of the following:
    • Select entities in a browser that supports the Entity Editor.
    • Select entities in the modeling window then right-click and select Edit <entity> from the context menu.
    The parameters defined for the selected entities display in the Entity Editor.
    Note: Selecting multiple entities displays the selected entity's common corresponding data. The rows that contain ### indicate that these fields do not contain common data, but can still be modified. When you modify the data, both common and ambiguous, the changes are applied to all of the selected entities.
  2. Click the value of the parameter to edit, and make changes accordingly.
