type2 (spring)
Creates a SPRING2N element for the body and plot elements for the head, the plot elements are created for visualization purposes and find operations.
![](../../../../images/cfg_radioss_2_type2.png)
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
View details for different types of realizations.
A list of realization types that can be specified for point connectors.
A list of realization types that can be specified for fastener connectors.
A list of realization types that can be specified for line connectors.
A list of realization types that can be specified for area connectors.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Create weld points at a predefined pitch distance so that the model build process can continue without the need to wait for the published weld data from CAD. Autopitch is useful when working with elements, not geometry.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
