Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
Create weld points at a predefined pitch distance so that the model build process can continue without the need to
wait for the published weld data from CAD. Autopitch is useful when working with elements, not geometry.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Restriction: Available in Abaqus, Nastran, and OptiStruct.
Creates a hexa element with RBE3 (Nastran/OptiStruct) or DCOUP3D (Abaqus)
elements projecting and connecting to the surrounding shell elements. This realization
does not use the shell thickness to calculate the hexa offset, therefore the hexa will
project and be touching the shell elements.
For Nastran and OptiStruct, this
realization uses the prop_nastran_acm.tcl property script. For
Abaqus, it uses
prop_abaqus_acm.tcl.
ACM Realization Options
Option
Action
thickness
Select a thickness
option used for dimensioning and positioning hexas.
shell gap
Project the hexa spot to touch the shell
elements.
The position is independent from any thickness.
equival. (T1+T2)/2
Create hexa elements with RBE3 elements projecting
elements.
This realization uses the shell thickness to
calculate the hexa offset from the shell elements.
In the case where the model is a 3T connection, the
acm (equivalenced-(T1+T2)/2) realization will join
the hexa elements.
detached (T1+T2)/2
and connecting to the surrounding shellstr
elements.
acm (detached-(T1+T2)/2) realization will not join
the hexa elements.
Figure 3.
mid thickness
Calculate the hexa spot size (thickness) as the air
gap between the two connected parts. If there is no
gap, or even a penetration, the hexa spot size will
always be modeled with 1.0.
const thickness
Specify the hexa spot size (thickness).
maintain gaps
Calculate the hexa spot size (thickness) as the gap
distance reduced by two times the specified value
for maintain gaps.
num hexas
Create a hexa cluster
with 1, 4, 8, 12, 16 or 32 hexas, which are arranged in a
predefined pattern.
Figure 4.
Note: Available for all ACM realization
types.
coats
Define the number of
hexa elements required along the thickness. Multiple solid coats
are supported.
orthogonal
faces
Force the creation of
perfectly orthogonally-shaped hexas.
Figure 5. . The two leftmost realizations were performed with the
orthogonal faces option enabled.
Note: Available for any kind of ACM weld, if num hexas is
set to 1.
