Open the Connector Browser
Use the Connector Browser to view and modify connectors in the current model.
To open the Connector Browser, first navigate to the
Connectors ribbon, then click the satellite icon
that appears when you hover over any of the tool in the Create tool set.
- The Link Entity Browser, located in the first pane, displays information about all of the linked entities in the model and Connectors groups.
- The Connector Entity Browser, located in the middle pane, displays a tree view of all the connections the model contains. HyperWorks organizes and displays the connectors in different folders based on their respective realization type. The names of the folders are obtained from the FE configuration names that are specified for respective solvers in the feconfig.cfg file.
- The Connector Entity Editor, located in the last pane, displays attributes assigned to the connector(s) selected in the Connector Entity Browser.
- Add Links
- Remove links
- Update links
- Find Connectors from Parts or Links
- Find Connectors from Realizations
- Find Links from Connectors
