Create and Realize Connectors
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Navigate to the Connectors ribbon then select any of the
tools in the Create tool set to define the associated connector type.
- Point
- Fastener
- Line
- Area
On the guide bar, click
to define connector options.
- Use the selector on the guide bar to choose an entity type, then select features on which to create connectors.
Use the options in the microdialog to further define
the connector.
The following options are available for all entity types and tools.
Option Description Move/Morph ( )
Relocate sections or the whole connector to a different position Link Edit ( )
Opens a dialogue that allows you to adjust the link detection logic. Show/Hide Projections ( )
Show and hide the pre-projections that indicate where the connector will connect to. Other options are dependent on the entity type and selected tool.Option Description Trim ( )
Split the connector at a selected position. Available for node list, line, element, and surface selection.
Partition ( )
Partition the seam connector if any part of that connector does not have projections. Only available for the Line tool.
Pitch and Density - Pitch (
- Adjust the number of significant points along the connector line by given spacing.
- Density (
- Adjust the number of significant points along the connector line by a number.
Available for node list and line selection in the Point and Line tools.
Line Interpolation - Straight line (
- A straight interpolation line is created between the
selected nodes.Figure 1.
- Interpolated line (
- A smoothed interpolation line is created between the
selected nodes.Figure 2.
Available for node list selection in the Point and Line tools.
Line Creation - None (
- Leave the line selections separate.Figure 3.
- Combine Smooth (
- Combine selected lines with an interpolated line.Figure 4.
- Combine Straight (
- Combine selected lines with a straight line.Figure 5.
- Mid Line (
- Generate a midline between selected lines.Figure 6.
Only available for line selection.
Remesh ( )
Remesh the connector surface. Figure 7.Available for any selection type in the Area tool.
- Pitch (
Use the drop-down menu on the guide bar to assign a
control to the connector.
Choose a previously defined control or click Create New to open the Control Manager and define a new control. If you select Undefined, the connector will be created without a control.
By default, an assigned control is realized.
On the guide bar, click one of the following:
- Save changes and stay in the tool
- Save changes and close the tool
- Exit the tool without saving changes
