ValueMapToNode
Maps values from a source model to nodes on a destination model.
src
A value table.
src_coord
Coordinate table associated with src elements.
dest_coord
Coordinate table associated with destination nodes.
elems
Element entity table in from model.
radius
Search radius around the destination node (default = ”auto”).
ctol
Coincident tolerance (default = 0.00001).
srcTransformIDList
Three space separated node IDs to transform from source model space (default = null – no transform).
destTransformIDList
Three space separated node IDs to transform to destination model space (default = null – no transform).
aggregate
An aggregation mode (avg, sum, min, max, extreme).
max_depth
Spatialization depth (default = ”7”, maximum = ”12”)
Outputs
answer
A nodal value table.
  • src and answer must be of the same format.
  • If src is a vector or tensor, it should be relative to the global system.
  • If one or more elements are within the coincident tolerance, only those elements will be processed (elements within the mapping radius, but outside the coincident tolerance will be ignored).
  • Elements that are inside the mapping radius to the destination node will be processed based upon the aggregation mode.
  • The aggregation rules for mapping are the same as those in the binding change operators (see Binding Change Operators).
N/A
XML Example
<call name="ValueMapToNode" src_coord="src_coords"
dest_coord="dest_coords" elems="from_elems"
radius="1" src="global_stress"
aggregate="avg" scale="auto" answer="answer" />
