Read Units Block
This function gives input to all the attributes in a UNITS block.
C Calling Sequence
int c_rto_read_units_block(char *lS, char *fS, char *mS, char *aS, char *tS);
Arguments
Argument Type   Description
lS Character Array Input The length string from TeimOrbit file UNITS block.
fS Character Array Input The force string from TeimOrbit file UNITS block.
mS Character Array Input The mass string from TeimOrbit file UNITS block.
aS Character Array Input The angle string from TeimOrbit file UNITS block.
tS Character Array Input The time string from road TeimOrbit UNITS block.
