Read Integer
This function reads an integer value assigned to an attribute from the specified block.
C Calling Sequence
int c_rto_read_integer(const char *block, const char *attrib,  int *alen, int *ival);
Arguments
Argument Type   Description
block Character Array Input This contains the block name in a TeimOrbit file.
attrib Character Array Input This contains the name of the attribute inside a block.
alen Integer Input This contains the number of characters in the attribute name.
ival Integer Output This returns the value of the attribute.
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_READ_INTEGER_F2C(char *blockName, int len1, int *blockNameLen, char *attributeName, int len2, int *alen, int *ival, int *success)
Arguments
blockName Character Array Input This contains the block name in a TeimOrbit file.
blockNameLen Integer Input This contains the number of characters in the block name.
attributeName Character Array Input This contains the name of the attribute inside a block.
success Integer Output If the value is read then success return 1 or else 0.
