Read Table in a Block
This function locates the start of a table in a block in a file. The table is denoted using “{“ and “}”.
C Calling Sequence
int c_rto_start_table_read(const char *block, char *form);
Arguments
Argument Type   Description
block Character Array Input This contains the block name in a TeimOrbit file.
form Character Array Output This contains the table column headings.
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_START_TABLE_READ_F2C(char *blockName, int len1, int *blockNameLen, char *format, int len2, int *formatLen, int *success)
Arguments
blockName Character Array Input This contains the block name in a TeimOrbit file.
blockNameLen Integer Input This contains the number of characters in the block name.
format Character Array Output This contains the table column headings.
formatLen Integer Output This contains the number of characters in the format string.
success Integer Output If the value is read then success return 1 or else 0.
