Read Spline in a Table
This function reads spline in a table of a block in a file. The Spline is a list of X and Y values in a block.
C Calling Sequence
int c_rto_read_table_spline(const char *block, int maxPairs, int *nPairs, double *values);
Arguments
Argument Type   Description
block Character Array Input This contains the block name in a TeimOrbit file.
maxPairs Integer
nPairs Integer
values Double Precision Output
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_READ_TABLE_SPLINE_F2C(char *blockName, int len1, int *blockNameLen, int *maxPairs, int *nPairs, double *values, int *Success)
Arguments
blockName Character Array Input This contains the block name in a TeimOrbit file.
blockNameLen Integer Input This contains the number of characters in the block name.
maxPairs Integer
nPairs Integer
success Integer Output If the value is read then success return 1 or else 0.
