Property File to SI Conversion Factors
This function converts the units from the property file to SI units.
C Calling Sequence
int c_rto_file2si_conversion_factors(double *cFactors);
Arguments
Argument Type   Description
cFactors Double Precision Input Converts all the units from TeimOrbit file to SI units.
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_FILE2SI_CONVERSION_FACTORS_F2C(double *cFactors, int *Success)
Arguments
success Integer Output If the value is read then success return 1 or else 0.
